J30Guy612 »
https://forums.nicoclub.com/j30guy612-u51964.html
Fri Feb 09, 2007 7:53 am
Keep us posted after trying pressing the gas pedal to the floor for 10 seconds, then starting.
Also in my J30 I can hear the fuel pump if I listen VERY closely, no music, windows up, etc. You may want to turn the key to the "ON" position, and you should hear a slight whirring from behind the rear seats (you may actually have to climb back there to hear it). This will also tell you if it's receiving power or not if you don't have access to a volt meter.
If both of these options don't provide any help, it might be worth it to check the ECU codes. There is a sticky at the top of this forum about how to check the ECU codes. Basically remove the passeneger side kick panel (right side near where the passenger's feet would be), 3 bolts that hold the ECU in, and then check the codes via the instructions at the top of the forum.
I would rule out the freezing gas, I don't see that being the problem.
However, if it's cranking and it's not turning over, in my experience with other cars, thats usually fuel related. If you can determine it's getting power, and it is then you might want to check the fuel pressure.
I know I didn't have one handy, and this picture is a simple fuel pressure setup you can make if you have a decent sized Ace hardware of plumbing supply store in your area:
Lastly, has the car done ANYTHING like this since the remote starter was installed? If it hasn't acted up once, and worked fine for 3 weeks, then the wiring is probably fine, just want to bring that up as well. If you've had any problems since the remote starter was installed, you may want to look into this as well.
Basically:
Try gas pedal to the floor
Try the injector fuse
Listen for fuel pump getting power
Check ECU codes
Check fuel pressure
Those are all the things that I can think of to help you narrow down the problem, there might be an easier way, just my two cents. Also, check out the Trouble Diagnosis section in the FSM, there is probably a section about the exact problem your having.
Good luck, I'll be checking back to see how you make out!
Hopefully it's something simple
