Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Sat Jan 10, 2004 12:01 pm
Sounds more like dirty contacts in the emergency flasher switch... or maybe a bad connection. The Emergency flashers just use both sides of the turn signal flasher at the same time, so it's somewhere behind that in the circuit.
Intermittant problems are a pain to diagnose, since they seem to fix themselves while you're working on it... I'd wait for it to break completely unless you use your emergency flashers a lot more than I do!
Heath
