Emergency - Can't Get Shifter Plate off transmission
Underground706
Ok, I installed a short shifter on my old S14 and all I had to do was remove the 6 bolts holding the shifter onto the transmission.
In my S13, I removed the 6 bolts, and the snap ring, and pulled the shifter lever out. But the plate that the 6 bolts go through(the control cover) is stuck on the top of the transmission. How do I get it off?
I can't drive anywhere until I get this figured out and I don't know what to do!
Please Help!
Modified by Underground706 at 9:30 AM 4/9/2005
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
have you tried prying it off??
Underground706
I tried to pry it off w/ a screwdriver but it wouldnt budge and I bent the metal around the hole exposing the transmission.
Do I need to just put more effort?
BomexS13
'00 Toyota Celica
I wonder if somebody put silicone on there. Mine came right off after taking off those 6 screws..
Dattebayo
use a hammer and tap the side of the plate with quick wrist snapping motions. If that doesnt work, get a razor knife and cut the space between the plate and the transmission. Careful not to score the transmission half.
fiznat
Car: Grown up :(
are you sure you got the bolts in the front portion of the plate? Im not sure if there are normally 6 or 8 bolts but there are two up front that are a beyotch to get to.
If you did, just keep working at it. Try to avoid prying: tap the thing from the sides as much as you can, it'll come off.
ILikeMy240sx
Car: SR Power
Yup there are 2 more bolts at the front which can only be accessed under the car... applies to both S13 and S14. I think there are total of 6.. not 8
Underground706
There are 6 bolts holding the control cover on the transmission.
I tried tapping it loose but it didn't work.
I'm going to try and put it back together for now.
Dattebayo
Dont be afraid of it, boy! Smack that metal, you cant really hurt it.
