Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Tue Sep 04, 2007 2:57 am
If the shoes are adjusted properly, then the emergency brake should be OK.Like you said, if the shoes are adjusted in, then the emergency brake cable has to travel too far, and the handle will "top out" so to speak before the brakes are engaged.Another thing if you don't mind: Try hitting the caps lock button so that the little red light on your keyboard is out.Typing in capital letters denotes SHOUTING.Thanks.
