Clipsed »
https://forums.nicoclub.com/clipsed-u53627.html
Mon Aug 27, 2007 9:53 pm
all you need is some fishing wire and goo-gone, and some rags. Place rags under the nissan emblem on the bumper to catch any goo-gone that runs down. Soak the emblem with goo-gone, let it sit for about 5 mins. and soak it again, take the fishing wire, and slowly work it back and forth between the body and emblem. IT SHOULD slide VERY EASILY, if it is hard to work, let the goo-gone soak longer, cause if you do it while it is not easy, you risk scratching it. Once you get it off, wash everything up nicely with car wash soap and water, and BLAMO! You are done.
