Emance tune
Drifticidal_Rob
Car: 91 240sx
Hello, I haven't really posted on here, but I look at it just about everyday. Well any ways I have rounded up just about everything I need for my turbo setup. I was wondering how to get a hold of the guy that does the Emance tunes. Any help would be great. So far I have a jgs mani, s15 t28 turbo, sr20 down pipe, stock side mount, 370cc injectors, z32 maf, new fuel pump, and all the oil lines. There might be some stuff I forgot.
480sx
Car: 1996 Pearl White 240sx
---> E-Mance
DevilMB3017
A JGS mani is a T3 flange, and the S15 turbos are T2 flanges. I'm going to assume you've changed the flange? Sounds like your set with everything else though
eazye2000
Car: S13 KA-DET
His name is Jason. His e-mail is [email protected]
Let him know EazyE2000, or Eric sent ya'..
Drifticidal_Rob
Car: 91 240sx
DevilMB3017 wrote:A JGS mani is a T3 flange, and the S15 turbos are T2 flanges. I'm going to assume you've changed the flange? Sounds like your set with everything else though
Yeah, I pretty much got my whole setup from an sr so I used the flange from that to fix my mani.
DevilMB3017
Awesome. Sounds like you have a good grasp on what your doing.
Keep posting pics as you build. I didn't, and wish I did. I have pretty much 0 pictures from the build process and regret it.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
E-Mance +1111
you might want to add in a NISMO FPR TYPE B w/ NISMO FPR fittingi was running my stock FPR and it failed on me in less than a week after i installed my Wal-bro 255 fuel pump
turbonola
Car: 91 240sx coupe
you can also look into a guy named quincy in houston. http://www.qgarage.comhis tunes power most of the houston/ new orleans ka-t's.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
turbonola wrote:you can also look into a guy named quincy in houston. http://www.qgarage.comhis tunes power most of the houston/ new orleans ka-t's.
Although I believe E-Mance has more upgradability, q-garage can make some real reliable tunes, in t2 form, I've seen a couple cars tuned by him, and they get the p*ss beat out of them, still runnin strong
and it's http://www.q-garage.com
WDRacing
If you can tune the fuel anywhere from 10.8:1 to 12:1 and simply retard the timing on boost you've got a winning tune...lol.
Once these guys get the base tune down, they can make almost infinite adjustments. Like Emance for instance... Easy basically unplugged his friggin wastegate so that the only thing limiting boost was the turbo itself...lol. He knew he had more then enough fuel for any amount of boost that his turbo would put out combined with an ecu tuned for big injectors. Bam, instant 12's on a SSAC T2 mani with a GT28 turbo.
That is a great example of how you can save money in some places and spend it in others and still have a reliable and fun car.
WD
Drifticidal_Rob
Car: 91 240sx
sounds good thanks for the advice guys
