emance install problems.
silviaS13lover
Car: yellow llama onevia
ok so i got the chip and had my friend put it in. (he's pretty good with soldering etc) so i get it done and put it in my car. the car won't start now and the relays keep clicking. i don't know whats going on. wtf.
Ekinchheng
Car: '93 Nissan 240SX Coupe
Try to use a difference ecu to start the car. If it does the same thing, then someone is wrong with the car. Have you tried useing the ecu on a different car to see if it does the same thing?
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
Do you have a picture of the ecu? probably did something wrong. you should email jason.
silviaS13lover
ok, so im completly fed up with this. so ive decided to sell everything i have. i need my car running and i can't keep messing with this. so if you've seen my setup and are intersted in parts, lmk.
240sxvaj
silviaS13lover wrote:ok, so im completly fed up with this. so ive decided to sell everything i have. i need my car running and i can't keep messing with this. so if you've seen my setup and are intersted in parts, lmk.
You should of sent your ecu to jason and let him install it, he will make sure it works!
I was in the same boat for a while, but after i got my ka-t running good, i love the torque.
Just double check everything, its probably something small, we all go through a lot of crappp because we are too anxious.
240sxvaj
what kind of wideband you running?
send me some pix to: [email protected]
thanks!
Zippy69
Car: 1993 240sx coupe
I hate to see you give up so quick. Take the board to a TV repair shop and have them check the soldering. Give Jason at E-mance a call and tell him what happened, he is a great guy and will go above and beyond to help. Make sure That you have the chips in the right direction. The little divot in the chips should both point to the 14 pin chip that was already soldered on the daughter board.But again, contact Jason at e-mance. He wants his customers to be happy.
silviaS13lover
i removed the turbokit. it runs now. im happy. maybe ill just hop on the sr bandwagon. lol jk. thanks for all the help.
240sxvaj
silviaS13lover wrote:i removed the turbokit. it runs now. im happy. maybe ill just hop on the sr bandwagon. lol jk. thanks for all the help.
i dont want to say this but.......
sell your car and get a hondalol!
silviaS13lover
never!!! lol
240sxvaj
SO.... still want to sell the wideband to me? pix would be great THanks
silviaS13lover
yes. look on google. type in plx devices wideband. in the mean time ill get pics of mine.
toofordee
wideband still for sale? send pics to [email protected]
S13FX
Car: '69 l20b Dimeski :)
The reason why your car was clicking was either because your friend damaged the chip while soldering, or he had a bad connection with one of his soldering points.
The proper way to do this is to unsolder the old chip which is a ***** cause its also epoxied on there so it stays preserved.
Then buy your self a ZIF socket (Zer Insertion Socket) solder that in place of the old chip.
Then you can swap chips on the go as much as you wish. You never want to apply so much direct heat to a eeprom or it will ruin it.
Iv done it my self, and you get the clicking as a result.
240sxvaj
Something good to know. But it's too late he already gave up and planning to go sr. sad that he wont be able to feel the torque of the KA.
silviaS13lover
yea. this is gay. wasted lots of time and money.
WDRacing
If you can't turbo a KAT, then going with an SR swap will be no easier. I assume you're paying for someone to do the swap for you, or else I have a feeling it will end with you giving up...again.
WD
240sxvaj
WDRacing wrote:If you can't turbo a KAT, then going with an SR swap will be no easier. I assume you're paying for someone to do the swap for you, or else I have a feeling it will end with you giving up...again.
WD
LOL! i can picture him going crazy. If you going sr i rather you go with s14 motor or s15, more power than s13 sr and not really a big price difference.
