eazye2000 »
https://forums.nicoclub.com/eazye2000-u30064.html
Fri Aug 01, 2008 7:27 am
The harness basically lets you run an OBD1 ECU in your S14. You can tune the S13 ECU to whatever you want. ROM wise. And then swap back your S14 ECU when it comes testing time. Just swap back the corresponding Injectors, MAF, and anything else, and you should be golden to sniff/test.Also keeps you from chopping your harness. Also, wiring in consult will help you keep track of what's going on. Just plug up to DataScan, or any other consult softward, and you should be good to do.
Looking to charge 100 bucks for the harness with consult connector. Fully tested and guaranteed to work since I have an S14, and I can plug in an S13 ECU and work out the bugs if there is any. Going to be bumping the price after I get established, because I have to source the parts(time), buy the parts(money), and then take the time putting everything together(more time).At 100 bucks each, I make approximately 9 dollars an hour doing this. Which isn't much considering it's tedious, nerve racking, and plain old boring. I have already incurred the cost of parts to make 3 more of these. Which it cost's roughly 45-50 dollars to make when it's all said and done. I make more sitting on my butt at my 'real' job. lolI will be going up to 125-150 after I get established.
Or pay RyWire like 250 for them, whatever. I think some guy on 'the ORG' was charging 180 for them, but quit making them.
Hope that's enough info. I guess if you cant figure out what it's used for, you don't need a KA, or even a turbo for it..
