DRIFTEADOR »
https://forums.nicoclub.com/drifteador-u23379.html
Thu Sep 08, 2005 3:59 am
chances are half of those cells will never be used in real world conditions but you still fill them just in case. its not likely the motor will see 20psi at 1500rpm or, on the other end of the spectrum, 12psi vacuum at 7000rpm, most likely doesnt spool at 2500rpm either (unless its pulling a tractor ). with a 3d map (load/rpm/fuel as opposed to safc's 2D, throttle/fuel only) it doesnt matter if you start adding fuel at 500rpm while in boost cause it wont read it. like red-kat explained, it takes from the x (load) and y (rpm) axis and figures how much fuel is needed based whats filled in the cell, or interpolated cells.
