Neil wrote:Why would you spend $600 for 40hp either??
Or more specifically, If you're sticking with the T28, what reason have you got to even consider additional fuel management at all?? Please don't tell me you want to tune for an open element intake filter and large diameter exhaust system.
And your estimate is a bit high. if you do it right, you can easily get a PFC and tuning for well under $1500 total. But that's what you have to pay to do it right, which you're apparently not doing if you're inflexible about doing real mods and just want to "get the most" out of your "bolt ons".
Get a boost controller and don't go over 14psi. There, I just saved you $1200.
No hard feelings, man.. but honestly, just because it's a j-spec turbo engine doesn't mean basic bolt ons are any more worth spending nearly a thousand dollars to compensate for than if it were a civic. A FMIC and cams will even make noticeable gains on the stock tune.
Modified by Neil at 11:51 AM 6/24/2008
the t28 is all I need for my car and 370cc injectors are not enough for the turbo. I tuned the safc on the dyno and was able to make 251to the wheels on 11psi, 16+whp from before it was tuned on the safc. It's not the fact that it's a "j-spec turbo engine", it's the fact that I want to run a little more boost, and that little more boost should set me at the power that I want. I don't mind spendin cash to buy injectors and n62 maf and headgasket, but I just can't find myself to justify using a standalone for a nearly stock motor. I'd stil be doing it right with a rom tune, and the reason I ask about the emanage is because it can tune ignition timing and many other things that other piggybacks don't do
if I'm going to go standalone, I will just upgrade the turbo
