eManage Ultimate MAFS Question
Iamjohnhayes
Car: 89 Single Cam Hatch
i heard that an N60 maf out of a maxima can be used with emanage if you set it up as a 300zx n62 maf. I was just wondering if this is true or if anyone else has even heard about this.
I dont see how it would b/c even though the mafs are the same size the N60 doesn't support the horsepower of the N62 (Anyone know why).
Personally im more interested in the fact that it flows a lot better than stock than the HP it can support b/c I only plan on running the mafs while not in boost and a gm 3 bar while in boost.
Edub1
Car: 89 240sx KA-T
The stock MAF is more than enough in conjunction with the pressure sensor. It will not restrict intake flow. Do you have the Ultimate yet? How much you have into it?
Iamjohnhayes
i have the ultimate it is in my closet awaiting me sending out my 460's to deatsch werks. and honestly the stock maf goes from like (not exact numbers) 2.5" or so down to like 1.5" with a "wall" in the middle. that has to cause some more restriction.
I would also be interested if anyone knew a MAF that was emanage compatable (knowing the hotwire would be great) that was less "touchy" than our nissan mafs.
