Emanage Ultimate issue with MAF failure.
mxkid54
Car: 1996 240SX SE
Just to share an experience and solution with fellow RB and Emanage users. Last week I had a wire short in my 0-5v signal from the MAF. The car would not run in limp home mode with the e-manage making the adjustments for the Z32 maf. Once the MAF was changed back to RB25 (for me) and the corrisponding maps disabled the car would crank in limp home mode. As a side note when I hooked up my laptop the emanage did give me a No air flow meter input voltage error. Hope this may help out others if they have a similar experience.
maryjane
did you have all of the jumpers hooked up correctly in the emanage box? and do you have the setting on the laptop dialed correctly?
mxkid54
Car: 1996 240SX SE
Yes, I have been running this setup for around a year. My issue was the short in the wire but I was confused at first because I could not get the car to start.
