eManage Ultimate Injector Wiring
Iamjohnhayes
Car: 89 Single Cam Hatch
Just wondering how you guys have wired your injectors i plan on wiring them ch1 - inj1 ch2 - inj2 ....ect. but i also heard someone bring up about wiring them in firing order.
gyfer
Iamjohnhayes
that link doesn't cover the kae b/c there are different pinouts on the ecu for th e and de.
Chris@AMS
Car: 91 Nissan 240sx
I have mine hooked up as inj1 - ch1...
make sure you dont forget to hook up the ground wire.
Iamjohnhayes
basically what i was planning but i just was wondering if anyone had done them in firing order. Hopefully i get this all wrapped up tommorrow after i scope muy cas to figure out which out put i need to wire the e manage to. I figured i would need to use the out put that only has the four signals for the cylinders not the 360 that does the crank angle.
BlackHat
Car: 1989 Nissan 240sx Hatchback
If you find out which pins those are, post it back up here. I'm going to need to wire to those soon also.
Iamjohnhayes
i almost habve it worked out i just have to call trust to see if they wante the 360* crank angle signal or the 4 signal output for the cylinder tdc from the optical cas
gyfer
