emanage ULTIMATE in s13 ka24det
blackS13
Car: 1988 Celica Alltrac turbo/ 1993 240sx
i need hoW to get my car running with the turbo on it. i have a ka24de with a turbo stock injectors and the emanage ULTIMATE all wired in but iT just wont start! i need the cc output of stock injectors, cycle lag time, if the wiring for the injectors have to be in a certain order or if it goes injector 1 to injector input 1 which is the way he had it wired, like for the sr20det it said 370cc and .7 lagtime. i just want a base map at idle so i can take it to get further tune and dynoed
gsx
Car: nissan
did you set the switches in the emanage box? if its anything like the refgular emanage then you have to set switches in the box itself...hope that helps
