Wel
rustest86 wrote:i think i have everything you need. i have a pdf of the jdm greddy manual for JUST the dial ajustments, software, and a walk though on how to make your own transfer cable. i also have a map if you want to mess with it, but if you do want it, it is for a different car with a different setup and will need tuning to run right, but it gives you a starting point. also search yahoo groups for emanage, LOTS of helpful info and software. the thing on how to make your own cable works, it cost me $16 to make it. if you need help on wiring i can look at my trust harness and make a wiring diagram for you, or look on rhdjapan.com. the trust plug and play harness is only $130. that might be worth your time, and only takes a min. to hook up.
Wow man, thanks ALOT for all the useful help!
dude, that would be awesome if you could do me a wiring diagram! I actually just bought the support tool software and cable for 20 bucks from a friend. ; )
But yea, the wiring diagram would be fantastic, i think we are going to try to put this all together tonight, or tomorrow, depending.... We are pretty confident on our ability to wire stuff, just need the diagram, and i dont mind wiring into the OEM harness, no big deal for me.
Thanks again man!
