Emanage related mafs question
Iamjohnhayes
Car: 89 Single Cam Hatch
does anyone know what engine the maxima n60 maf came on that is in the emanage software.
Also can anyone think of any reason for emanage to mess up the way my car is running if i install it and am only tunning it to run a new maf. i was going to do the injectors as well but i figured they should wait till they are needed. basically i want to install the new maf since i know my old one is kinda off since its off of a pathfinder (looks exactly the same but has different numbers on it.). it would be help full if i could do some data logging before i go turbo.
Iamjohnhayes
anyone?
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
It came on maxima vg30e, 90-93ish
No idea about emanage.
Iamjohnhayes
thanks dude
deviousKA
No problem, good luck.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
My advise when installing multiple upgrades on your car.
Do one thing at a time, make sure it works right then procede. IT makes life much easier especially if you run into a problem.
