Emanage on SOHC KA25E-T
gyfer
Does everyone have use their stock SOHC hot wire MAF, with Emanage ??What is your rotary settings ?? Is it 2-0-7 ??What's your hot wire settings ?? Do you use NS_HW-8 ??
Hook up my S13 with Emanage over the weekend. Car won't start. I am not getting sparks. Reconnect MAF back to stock, car will run fine. Ignition wires is not hookup to Emaage right now.
I think Emanage don't like SOHC MAF. Can it be true ??
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
No I run SOHC and EM. I can tell you later what the switch settings are.
gyfer
You are a life saver.I have been searching online for 3 days now, from nico, to KA-t.org, to various forums...
It will be great if we can share some info... :P
gyfer
Nobody else use Emanage with their SOHC ?? Still need help
bump
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Sorry it took so long to get an answer for you, been busy at work.
My rotary switches are set at 2-0-6
Hope that helps
Edub1
Car: 89 240sx KA-T
Have you considered a injector/MAF tuned ECU to use with the Emanage?
That way you can fine tune with the Emanage but not have your MAF signal and ECU all wacked out.
Piggybacks alone really confuse the ECU.
