emanage connection cable, help! input!
maryjane
a friend just wrecked his mr2 and he just totaled it out around a tree, he had a blue emanage box brand new in box for 60 bucks!
im wondering if instead of using the usb to 232 cable could i use a usb to usb cable to tune the emanage with?
instead of using the usb input on the blue emanage box to 232 port on a older lap top can i use a usb from the emanage to a usb on a laptop? thank for any input?
WhatsADSM
Car: 1998 240sx
Reminds me of that old movie short circuit. "Number 5 need input"
You can not use a regular off the shelf USB to USB cable to connect the emanage to your laptop. You either need to buy their special USB cable or make one yourself. zer...cable
Chaos the Xile
Car: 1974 Datsun 260Z
WhatsADSM wrote:Reminds me of that old movie short circuit. "Number 5 need input"
or he could buy a power fc, aem or something along those lines have a better ecu and not have to worry about all the greddy emanage bs...
maryjane
im ditching a afc neo for this so id say this is a upgrade, lol.
neo=
emanage=
its a upgrade at least
just waiting for the adapter harness to arrive
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
no you can not. HOWEVER there is a company over in the UK that makes the cables with software and all updates for like $40 bux +10 ship. if i find the link ill send it to you, i had mine within 2 weeks.
MeanGreenS13
http://www.giff-tech.co.uk/
theres your link! good luck, and remember, when installing firmware on Emanage Blue, UN HOOK THE IGNITION HARNESS! i forgot to and blew my entire ignition system up.
maryjane
nice! thanks! where can i load the info for the emanage box? as in the greddy software?
MeanGreenS13
they send you a disc with the cable, its included in the package. Emanage software as well as the update files which are becoming very hard to find
maryjane
ordered one last night! waiting for the package to arrive so i can eliminate the neo (finally)!!!!
anyone have a base fuel/ ing. map that i can use for a base map
MeanGreenS13
the emanage does similar things to the neo. It uses your factory fuel and timing maps as base maps. you adjust from there, its actually quite easy once you get everything set up. setting it up properly is a challenge tho
maryjane
i was worried with the neo because i could not control the timing.the neo was way out of its range trying to control a t-78, 720s and twin q45 mafs, the every 500 rpm range adjustments werent cutting it, ran like crap, was afraid to run more boost w/o being able to control timing.
