MAXIMUS Nismo »
https://forums.nicoclub.com/maximus-nismo-u648.html
Sat Dec 11, 2004 5:34 am
Here's an email conversation I had with the KYB people about suspension settings. Maybe usefull to some people
1 -----Original Message-----From: leo whylie Sent: Monday, November 29, 2004 9:43 PMTo: Troy HornSubject: [KYB.COM Contact Form] AGX questionImportance: High
hi, I have a 95 240sx. my rear struts are blown and I am conisderinggettging your AGx with Eibach Prokit. What is hte optimal setting forstreet use that will not prematurely damage the struts? What is yourwarrant like. What is covered and what isn't?
The car is never raced and is strictly a daily driver. (the wife evenhas to drive it)
thanks for your help
2-----Original Message-----From: Troy Horn Sent: Tuesday, November 30, 2004 1:49 PMSubject: RE: [KYB.COM Contact Form] AGX question
Front has a 1-4 setting, use setting 2Rear has a 1-8 setting, use setting 4.
KYB products have a Limited Lifetime Warranty. This warranty applies to the original purchaser of the product with a dated proof of purchase. The warranty does not apply to product that is misapplied, abused, or used in racing or commercial applications. The warranty is void if the product is used on excessively lowered (over 1.5")(Sport drops) vehicles or if an Aftermarket coilover shock system is used. Please contact your place of purchase, or a local KYB retailer, for warranty qualification and/or exchange.
3-----Original Message-----From: LEO WHYLIESent: Wednesday, December 01, 2004 6:16 AMTo: Troy HornSubject: RE: [KYB.COM Contact Form] AGX question
Thank you for your speedy reply.What are the stiffest settings you would recommend for my setup? - LEO
4This is up to you on how firm you want the ride to be.The AGX products have the following approximate damping force values.When adjusted, both rebound and compression damping forces change. Setting#:Relative Value 1 - Same as Factory 100
2 - Same as our GR2 products (10~15% firmer than Factory) 115
3 - 50% firmer than #2 172
4 - 30% firmer than #3 223
For an eight position adjustable product, the damping force values areapprox. the following: With #2 being Factory at a relative value of 100,
#1 = 95 (5% softer than Factory )
#2 = 100 (Factory damping force)
#3 = 107.5 (7.5% firmer than Factory)
#4 = 115 (15% firmer than Factory)(GR-2)
#5 = 143.5 (43.5% firmer than Factory)
#6 = 172 (72% firmer than Factory) #7 = 197.5 (97.5 firmer than Factory)
#8 = 223 (123 % firmer than Factory)
