eliminating cruise control
gumby
Car: '89 240sx sohc
i dont need this crap i'll never use it. any electrical issues or can i just disconnect it.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Rip out the harness to the steering wheel, go under the hood and remove the unit that is hooked up to the throttle and the motor assembly that controls vacuum to the cruise unit. Done.
Silviapower
Car: 98 240sx SE
why do u have to take it off does it really bother u that much hehehe :).
gumby
Car: '89 240sx sohc
well the new engine doesnt have it and i dont need it so consider it weight reduction or one less thing to break.
Silviapower
Car: 98 240sx SE
really i know someone else that make there cruise control to work on there SR. We'll if u dont want it do wat silvia007 said.:( good luck. Im from LA long drive to Las Vegas need some kind of cruise control u know to save some gas hehehehe :)
i2ice4m3
Car: COUNTERSTRIKE!
you can pull out the CC module behind the ecu also.
