justmerging wrote:The 205 hp figure is at the flywheel on 7 or 8 psi. If your running a stock boost solenoid and your car runs 12-13 psi, it's not working.
Actually it is running properly at 13psi. People running 7 just short change themselves.
The SR came with the boost control solenoid for a reason. If the SR's in the US without boost control solenoids run 7 psi normally, then why would Nissan put in a pressure controller to keep it at 7?
Nobody who has hooked up the stock boost control solenoid and was not throwing any ECU codes has stayed at 7 lbs. 7 lbs was probably started by heavy throttle since they probably did not hook it up on their first SR swaps. Then they made that FAQ which basically turned into a bible for SR's.
