Even A maxed out alternator will not draw as much power as a clutch fanbruinbear714 wrote:No point in leaving your fans on all the time as it wastes more power than the stock clutch fan when the thermostat isn't open.
. how is this a clutch fan is mechanical and puts strain on the motor... electric fans are electric and put no strain on the enginebruinbear714 wrote:[/url]. No point in leaving your fans on all the time as it wastes more power than the stock clutch fan when the thermostat isn't open.
This is true however the alternator will have to increace output to supply the voltage drawn; this creates the mechanical strain however it is negligible compared to a clutch fansrdub-t wrote:. how is this a clutch fan is mechanical and puts strain on the motor... electric fans are electric and put no strain on the engine
ya, thats what it was for the one i got with my discount at Advancedrifterhype wrote:Thanks bro and you said it is about 25 dollars thanks with the info.
