eletric fan
scottsnissan
Car: 1995 240 sx se
i was wondering what size eletric fan should i at least run on 95 240 sx , i have no motor mods are anthing ,Jus a brand new head and radiator,I have a 11 inch in my neon and was wondering if i can jus use that one ? let me know thx
fantabulous
Car: s14
im using the stock AC fan since it already mounted on the radiator. (no AC) i just got the permacool thermostat switch from heavythrottle. found a 4 prong relay that was not used relay box. this setup works great. no problems yet. stock nissan fan is pretty reliable. i just wired it for hi speed function instead, low speed is not used. if u still want aftermarket, my bro is using 12" fan, no problems. goodluck.
574-240sx
Car: Nissans, Toyotas, Subaru
NA you should be fine. I ran in to problems, turboed at a drift practice, I started to overheat after my runs. I went to the junkyard picked up a stock GM electric fan with shroud. It works great now, no more overheating. I thought I could get away with using the a/c fan, but its too small and is only met to be a backup. Nick
fantabulous
Car: s14
you were drifting tho. this setup works good for daily driving.
