Electronics gurus? Sub question-
Post all your Nissan electronics, car audio and stereo questions here!
S14Zilvia
Car: '90 300ZXTT, '92 S13 coupe, '06 Ram 3500 Mega, '93 del Sol Si
I've got a rockford sub in a q-logic box with a rockford amp and capacitor.
When I connect the wires from the amp to the terminals on the sub box it won't play, but when I just hold them lightly to the *outside* of the terminals it plays great. There's also a little sparking when I connect them.
It's the type of terminals that clamp down on the wires- cylinders that you put the wires through and are pushed up with a spring.
Any ideas?
lessthanjakejohn
There is a stereo forum: http://www.nissaninfiniticlub....id=99
Doogz
Car: '89 240sx coupe
Well first of all those terminals are gay as shat and i hate them very much. Secondly, why is it sparking?? Are you connecting the subs with the amp on or is it just sparking all the time for some crazy miswired reason?
1991240xs
take out the terminal and see if they are shorted together somehow-
S14Zilvia
Doogz wrote:Well first of all those terminals are gay as shat and i hate them very much. Secondly, why is it sparking?? Are you connecting the subs with the amp on or is it just sparking all the time for some crazy miswired reason?
A couple speaker guys who couldn't understand why it wouldn't work were connecting them when the amp was on and it was sparking. they flipped out and said that shouldn't happen and that it was a problem with the amp.
I don't think the terminals are shorted together, how could that happen?
diamondj30
Car: Not to low , not to high , just right .
happens all the time,the rca inputs get loose.some peeps silicone them.dont try it yourself.vibration ussaully being the culprit.just saying it happens.some amps are p[lagued and some not.
S14Zilvia
diamondj30 wrote:happens all the time,the rca inputs get loose.some peeps silicone them.dont try it yourself.vibration ussaully being the culprit.just saying it happens.some amps are p[lagued and some not.
So I do what about it?
creophus
Car: 240SX SE & 200SX
I've had similar problems...here's my two cents. Sometimes when using those stupid terminals on the sub box, it's easy to push the wire in too far or not far enough. That's probably why it works when you touch it to the terminal, where you can see the metal part no doubt. I think the RCA outputs on your amp are fine. Just yank out those stupid terminals and connect the wires to the speakers directly. If this works, then you know for sure it's the terminal connections. You can already see that's most likely the problem. If you are set on getting terminals, order some from ebay that are heavy duty. I personally advise against terminals, they are the weakest link in your stereo connection and should be eliminated. Let me know if that helps dude!
