I got a SOHC in my shed and I got one that should be running in my project but having trouble, no fuel.Was going to take next door on 10 acres of field and have some fun.But yes this is related to the DE.veilside180sx wrote:I take it you must have a DE, instead of the E I saw you mention was in your garage.=)
You have the 370's now... which will be good for the 250 whp mark.. If u plan on passing the 250 whp mark, then YES get the 555cc inj...Florida240sx wrote:Should I use the 550's and have what is it -50% on the SAFC or whatever % I need?
he didnt mean the SAFC is only good up to 250hp, he only meant that the e-manage will probably be a better choice because of the timing control option you get. they both have the same protentiol controlling fuel wise but i guess you get a lil more out of your money to buy an e-manageFlorida240sx wrote:K that's kinda what I gathered.So anything above 250rwhp need to get something better than SAFC.And if I don't go to dyno then get a wideband.Hmm only dyno around here that I know of only gives RWHP and that's it.Structure which injectors should I use?Show that 370 are right next to the limit think it was 274hp.
