Hey, I got a problem with my S14 w/SR swap. I was on a back road and did a quick run 1-3 and when I went to shift the car into fourth all of a sudden everything in the car shut off, engine turned off, tach turned off, etc etc but the clock was still running, the hazards worked, even the alarm which says when the door is open worked.
We opened the hood and found a blown ignition fuse after much rummaging around (we overlooked it). We replaced it with another 30A fuse and to my dismay the car still didn't start.
However, after replacing the fuse (and cleaning basically all the grounds in the engine bay) everything in the car works and you can even hear the starter click except that it actually won't turn over.
The voltage gauge reads around 12v which drops when I try to start it (into the 11v range) so I thought it was a dead battery. I charged the battery with a trickle charger and I checked the battery and it said it was 100%.
I put it back in the car and the voltage gauge still reads low. What could this be? Friends uncle (who is a mechanic) said it could possibly be a corroded electrical line (he said possibly the positive terminal) but I looked along the lines and there are no distinct bulges. It could be back further in the harness but is this most likely what it is?
In addition, when I turn the key into the on position the fans in the engine bay start (flexalites) but when I turn the key to start the car they turn off, and when I let off of the ignition they turn back on (when I am not trying to crank the car).
Another thing could be that the viper alarm is locking the car out and won't let me start it. I disable the alarm with the remote everytime so I don't think this is it...
Anyone else have a similar issue...?
