Electronics behind speaker in door panel?
bigfish303
Car: 2005 Subaru WRX
What is that whole assembly behind the speakers in the door panel that is housed in that yellowish plastic. Been using the search button, but coming up dry. It's a S13
JStrateger
Car: 1992 Nissan 240SX
I'm installing speakers right now and I'm wondering the same thing. Do I remove all this junk or what? Are they factory amps?
I have the active speaker system.
JStrateger
Here's a picture of what I'm talking about, I'm testing wires now to see if I can just take all this s*** out.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
JStrateger wrote:I'm installing speakers right now and I'm wondering the same thing. Do I remove all this junk or what? Are they factory amps?
Yes, it's the amplifier for the speaker in your active system. You won't need it if you're installing an aftermarket amp to power aftermarket speakers.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
yeah, I just put new speakers in and toby's adapters to I think either a 6" or 6.5" speaker.Much better then the stock size speaker, more selection too.
Run your own wire to the new headunit, its easier.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
i've never seen that before. neither of my previous s13's had that.
scotty-2-forty
numbnuts240 wrote:i've never seen that before. neither of my previous s13's had that.
Only the active speaker systems had them. Otherwise, you just had speakers with no electronics in the door.
JStrateger
I just finished gutting the amplifier from the drivers side door speaker, the speaker sounded the same with and without the amplifier... I just re-used the existing factory speaker wire, no way I'm running new wire, eff that, sounds like a lot of work for no reason.
I'm working on the passenger side now, going to leave the amp hooked up on this one and see if I can tell the difference.
Modified by JStrateger at 11:24 AM 3/18/2010
