Electronic Timing vs. Mechanical Timing
TRBOMOFO
Car: S13.5 built redtop
I know that the 15 BTDC and i did all that but
i have talked to people and they always refer to "locking electrical timing" like say if they are using a AEM they will do the mechanical timing adjustment then they will lock the electrical time at the certain base time and then from there they can tune the ignition maps accordingly
so does this make since
is there away or method on the SRs
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
They are refering to setting the "base" timing which is what you did. When you unplug the tps to set the timing it stops adding or subtracting to the base timing so that you can get it set properly.
TRBOMOFO
okay i was so damn confused i didnt know what the hell was going on thanks for the help
