Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Sep 08, 2007 3:08 am
Time to get use to spending maintenance and repair money.
I have a mantra that every used car even a 4 year old one needs at least $3,000 in maintenance and repairs ..............marginal things are worn just haven't failed yet.
Engineers design for 100k life to get that number many things last somewhat longer.
You can give up ypur spare time and educate yourself in automotive engineering, buy tools and test equipment or pay someone.
Assuming you are less efficient than an expert technican you will take 2-3 times longer to accomplish the same task CORRECTLY.
The usual problem is you don't have access to $50,000 in test equipment and tools..........no lift, no tire balancers, no air compressor, no parts inventory.
If a car needs 10-15 billable technican hours per year be prepared to spend 40 personal hours to learn the tasks before you start.
