Electronic oil sending unit
DammitBobby
Car: S13 91 KA24DET
I need to check my oil pressure since I have destroyed 2 turbos. I would like to get an electronic oil pressure gauge so I can monitor oil pressure inside the car. Can anyone recommend one that is reasonable? Also since all of them use NPT and not BPT what fitting do I need? I was also thinking of using
http://www.mishimoto.com/oil-plate-sand ... apter.html.
biggie
I just have the autometer gauge, can get a connector to convert BPT to NPT. I have mine in the extra fitting beside the OEM oil pressure sensor.
Can just retap that hole as well instead of buying an adapter. But would probably want to take the filter block off to do that.
