Postby
Amgberg »
https://forums.nicoclub.com/amgberg-u238021.htmlTue May 02, 2017 5:01 pm
I have notice weird electronic moter sound from the rear end. It's like a moter sound it does it at random times I was thinking fuel pump but idk. It has gotten louder. I was wondering if it's the hicas moter or leveling moter I'm lost.
Postby
Ilya »
https://forums.nicoclub.com/ilya-u159401.htmlTue May 02, 2017 9:24 pm
You got a video? Only motor I can think of back there is the fuel pump...do you hear it while the car is on or when you go into ACC mode on the ignition?
Postby
Amgberg »
https://forums.nicoclub.com/amgberg-u238021.htmlTue May 02, 2017 10:33 pm
Ilya wrote:You got a video? Only motor I can think of back there is the fuel pump...do you hear it while the car is on or when you go into ACC mode on the ignition?
Postby
steve_c »
https://forums.nicoclub.com/steve-c-u163301.htmlWed May 03, 2017 7:32 pm
Yes and while driving.
You are lucky! It is giving you a nice heads up that it is on its last legs!
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlWed May 03, 2017 10:33 pm
The headlight leveler isn't a motor, it's just a sensor/potentiometer that makes the motor at the front move. I'd eliminate that.
Not sure if the RAS motor will make random noises, but, is this happening while the steering wheel is turned? Any lights on the dash?
Without hearing the noise, I'd like to throw the possibility of the differential. I've read that they could whine while on the way out.
For the fuel pump, you don't have to drop the tank. Remove the rear seat bottom (which would be noise insulation here) and if that's the problem, the noise will be amplified while you ride around. The pump is on the right side.
Do the check as suggested, by pushing the button to the ACC mode and listen for the pump noise to compare to what your trouble noise is.
Yes, they could get louder towards the end of life as well.
If you ever get to the point of removal, here's a video from youtube
Postby
Amgberg »
https://forums.nicoclub.com/amgberg-u238021.htmlMon May 08, 2017 8:32 am
Well today I started my car and it stumble on start 3 times then 4th it starts as normal. Before I get the fuel pump was wondering if the m45 fuel pump resistor is in the rear as well and can it make noise?
