DanielC »
https://forums.nicoclub.com/danielc-u110482.html
Wed Dec 31, 1969 5:00 pm
I have been doing a few experiments, or tests of using a process of electrolysis to help remove rust from old parts. The basic process is this: Get some Arm and Hammer Super Washing soda, a plastic bucket, some old steel, or iron scrap, and a battery charger. You put about 2 or 4 tablespoons of the washing soda per gallon of water in the plastic bucket, and mix well. Put the scrap metal in the solution, connected to the positive lead of the battery charger. Connect the negitive lead of the battery charger on the part you want to derust, and put it into the solution without touching the scrap metal. You should see bubbles start rising off the part being derusted. Let the part sit for a while, maybe even a day or two, with the battery charger connected. When the process is done, the bubbles will slow down quite a bit, take the part out and then clean it. It will not be shiny and new, you still have to clean it, but it will clean a lot easier. The part will start rusting again if you do not get it dry. Do not let the part sit in the solution without the battery charger connected. If the current goes too high for the charger, pull part of the scrap metal out of the solution, or mix a weaker solution of washing soda and water.
So far I have used the process to clean the rust off a distributer/oil pump drive, so I could press the gear off, and use the shaft to pre oil an engine, and I also used the process to loosten a broken stud in stainless exhaust flange nut.
