Electrical short?
kibatheloanwolf
Car: 1987 D21 2.4L with a 5 speed manual trans
2010 Camry 2.5L with a 6 speed maunal trans
Here is the story..A while back I had installed a radio into my dash just for some tunage for when I'm driving around..Well After I had installed the radio I noticed my dashlights were always at a constant brightness. That made me think my dimmer knob had shorted out and so I took it out and didn't bother with it.
Now..I had to take the radio out to see if I could get the Cd Player working again and I turned on the headlights and such Boom No dash lights,so I started searching the fuse's to see if the fuse was blown. Nothing..Then I got the wild idea to try my dimmer knob again..
As soon as I hooked it back up it works..My question is..Could something in the radio be shorting out the dash lights?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The illumination circuit runs through the radio. It's usually an orange wire. By cutting that wire the dash lights no longer work.
kibatheloanwolf
Nope Just went out and cut it still staying on the brightest setting untill I unplug the radio then the Brightens and dims along with the knob
seang
Car: Ford Fiesta ST
Kiba, what movie is your avitar from?
kibatheloanwolf
I have no idea Seang Found it on 4chan in random
Rev_D21
I would guess the radio then. It should allow the dash lights to remain normal while it itself might have a night/day mode. Still it needs the ILL wire to complete the circuit.
kibatheloanwolf
Well Snipped the ILL cicuit and Traced down wires..They grounded my Stereo to the Cig lighter.. I'm going to trace things out later
JC87HB
Car: 1987 Nissan D21 HB
I say you should check out the wiring of the CD player... if wires got spliced it could be grounding out causing the CD player not to work and maybe ur light problem
kibatheloanwolf
Well I spent all of this morning Under the dash of my truck following my wires and suck They had snipped the Positive Off of the Factory cable and hooked it directly to the stereo and grounded it using the Cigarette lighter .So I ask.
Does anyone have The Wire Diagram for the radio and cigarette lighter?
Modified by kibatheloanwolf at 9:14 AM 12/2/2009
Rev_D21
What? Spark Plug?
kibatheloanwolf
Sorry Rev Just has been a long morning lemme fix that.. *Cigarette lighter
Rev_D21
89 should be close to the 93. Check NICOs FSM collection. Check out the 93 Pathfinder FSM, the truck is lumped in there.
http://www.nicoclub.com/FSM
Rev_D21
Sorry, 94. The circuits should be the same.
kibatheloanwolf
Thanks Rev it's starting to rain so I gotta pull her into the garage and work on her
RT22
Car: 1991 nissan hardbody
Do not share grounds take it to a chassis, more electrical problems are ground related than anything. Take the radio to chassis ground you can tie it to the bolts on the frame work that hold plastic cover that is below radio. The color code is on any plug adapter that you get at wal mart. Standard pretty much email me i think I have one and can email it to you if needed. [email protected] email me I will type up the one I have and shoot it back
