Nazgulmagefreak »
https://forums.nicoclub.com/nazgulmagefreak-u157149.html
Sat Mar 27, 2010 6:01 am
Ok, I have some kind of electrical issue. I originally thought my alternator was dying, but leaning more towards a wiring issue. Battery is good at about 12.76volts. Had alternator checked in car at autoparts store, battery checked ok and charging system problem. I was told to check all the wires and terminals. I cleaned both terminals, the positive from the alternator, and the battery ground to the chassis and engine. I cleaned the ground points to the engine and chassis. I then checked voltages, with 12.76V at battery with the car off and 12.76V. I found about 14V at the battery with the car on and the same at the alternator. I had the same auto parts store retest the alternator today, and again got good battery and apparently no output from the alternator according to their machine. The guy thinks it is not the alternator, but more likely somewhere in the wiring.
Here is what it does. I start the car and it starts normally, but sounds a little bogged down. Car drives fine and never dies, always starts on first try. Gauges remain off, along with odometer, cruise control and the SES light (which stays on all the time, due to O2 sensor prob.) is half-way dim. If I drive to 5-10 mins, usually the gauges will come on, but as soon as I press the button on the dash for cruise control, or turn on my blinker, the gauges and odometer shut off. They usually come back on a few seconds after I turn them off. I have checked EVERY fuse under dash and hood. But, headlights work both high and low, radio/clock works, brake lights work, and hazard lights work. I checked all the bulbs and not a single one is burnt out. Also, when the guages are not on, the power windows don't work.
I am lost on this one. It has lasted over a week, so I am thinking its not the alternator, cause the battery would surely be dead by now. I don't understand why the hazards work, but turn signals don't. Any help or pointers is appreciated.
