The car loses electrical power, when there is a load on the system. Mostly when I apply the brakes, at night with the headlights on. I notice the headlights dimming, and the engine idles a little bit rough. When I turn the car off, the security light flashes very quickly, and then loses power. If I try to start it up again, I get no power. If I open the hood and wiggle the Negative battery wire, the power will come on. I have replaced the alternator, and belts, the battery is brand new (750cca). I had a test done at a local Advance auto, and everything came back ok. I am no ace mechanic. I can usually figure things out, but if it involves electrical, I am lost. Any advice would be appreciated. Thank you in advance.
