SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Thu Jul 09, 2009 2:44 pm
The work that would be required to run all that wiring would not make that this an efficient repair for this incident.
Bypassing the BCM would be easier and require no adding of switches. Although you would need to study the wiring diagram for the circuit and do some rewiring, it would really be easier to save the money and buy the BCM. The module actually controls many of the body functions and when one goes the others tend to follow and once you start hacking into the factory harness it is very hard to go back.
Biting the bullet and replacing the BCM correctly will save many headaches in the long run. I would first diagnose the route cause of this issue to verify that there is no power on the signal wire out of the BCM before condemning it.
