Pirate_Freder wrote:well i figured that if i tested at where the fuse plugs in i would be completing the circuit with my multimeter. would i just use a gtround or the negative terminal for the negative to test voltage? (since there is only positive running through the circuit)
There is only positive but there is a short which will reveal itself as voltage.If you take voltage readings along the wire there should be zero voltage reading. However, if there is a short , there is a difference in potential which will read as voltage on your multimeter.
You might get some of those fuses at a junk yard. Not safe to solder them.
Im not too sure about the amps. Have not done this for along time. wouldnt a short blow the fuse in the multimeter. Or, if you didnt use the fuse you might have blown multimeter?
