Electrical Problems?
Nismo300zx
Car: 1990 300zx Twin Turbo
today my battery went dead and i change it.when i changed it was raining and the car started like it should.however i got home and tried to start it up again and it didnt..wat do you guys thinki it is?or did something electrical just get wet? if so should it start once its dry?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
What does it do when you try to crank it over? Anything at all? Clicking relays or anything of the such?
Might be a bad alternator. If the battery that you swapped in wasn't brand new, then it could be a dead cell in the battery
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
wet has nthing to do with it, when you replaced the battery, was it drained or dead? if the battery was wimply rained due to a bad alternatlr or voltage regualtor and you replaced the battery it too will drain out, assuming the alt/vr is good check the battery cables and make sure you have good solid connections at both ends of both cables and a good chassis ground on the firewall
TTZ32
Car: TT 90 300ZX
