Electrical Problems!
lukepeeff
Car: g20
So I'm a Dumb A** but about a year ago i jumped the car and fried some components. The radio, the keyless entry, the door locks, and the dome light. ive been going over the manuel that i got from this web site about my car but i cant find a common ground. ive checked all the fuses under the driverside box, and the box of fusable links under the hood by the battery they all apper to be good short of taking my multmeiter out there and checking the contunity between the the prongs of the fuse im at a total loss. please please help! any thing that this group could come up with would be great!
Cant spell to save my life by the way
ABNRML4U
Car: Nissan B13
Man, I wish I could help you really my guess is to start from the battery cables and then the fuse box by the battery and the fuse box below the dashboard. There is 2 fuse boxes on the nissan one under the hood and 1 below the dashboard. Just be cool take your time and it has to be a lose connection some where. just don't panic o.k. you might want to check the nicoclub on-line mechanic and see what he says. Good luck and I hope everything works out well for you. Welcome to NicoClub!!.
Faja
Car: 2009 Nissan Sentra
See if you can trace the live power source - radio or dome light might be easiest and see where in the fuse box it ends up and start testing your power from there. You definitely shorted something, could be fuse, relay or wire itself but there is a common connection somewhere for the items that are not working - it's just a matter of finding it. Easier said than done I know but that's my 2 cents worth.
uberstrafe
Car: '96 G20t
How did you hook up the clamps to fry stuff like that? You need some electrical diagrams stat, check for power and ground at all of those circuits and if it has both and still doesnt work then replace the switch, relay, or whatever you fried
