I am having some electrical trouble on my '91 240sx and i hope someone can help me out. A few weeks ago the EGI relay under the hood started buzzing. It would start to buzz when I opened the doors/hatch and wouldn't stop until the engine was started. Then a few days later, I noticed that the check engine light/oil pressure light ect would stay on with the ignition off with the key out.
Today i went to start it, and now nothing works. None of the lights work, the horn doesn't work.The engine would crank, but would not start. I eventually got it started, but it runs really rough and sometimes only on 3 cylinders. The tach is jumping around when the engine is at idle, and the temp gauge is all the way at hot and its still cold. Oh and if i try to turn on the headlights or press the horn, the engine will start to die. anyone have any ideas?
