float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Apr 07, 2005 9:19 pm
Ok, so I'm about at my wits end. I'm by no means a stranger to wiring and electrical, but this darn car has got me stumped. Ok, so here is the deal...
I've had the car for about a year. When I first got the wiring, I didn't do it the way I should have and just did it "good enough". It worked OK, but not everything was hooked up. It was hard to start cold and the butterfly's didn't work correctly. Due to a wastegate line blowing off I over boosted and fried the rings. So I pulled the motor and rebuilt it. I've finally gotten to the point where I put the motor back in the car and So I decided to redo the wiring correctly. On to the problem...
I think everything is wired as it should be. All I really did was lengthen wires that should have been lengthend the first time that I didn't do. I also wired up the solenoids for the butterflys, boost control, and that fuel pressure one. Due to some problems with intercooler piping, I don't have the turbo hooked up at all. I just used the intake pipe from my KA/E and have the car hooked up like it's NA. The car is still hard to start cold. I'm guessing that it's that stupid valve under the TB. After it start's it seems to run great and everything is fine EXCEPT the following; The BRAKE light on the dash comes on AFTER I start the car. If the ignition switch is in the Run position, with the E-brake down, the light is off. As soon as I start the car, the light comes on. Secondly, the Charge light is very faintly lit. I've checked everything that has to do with the alternator and it checks out fine. I'm getting plenty of voltage out of the Alternator and I've run the car long enough that if it wasn't charging, I would have discharged the battery.
I'm at a complete loss and I'm at my wit's end. NO codes on the ECU. All my grounds look good. I'm ready to ditch this stock crap and get an SDS. Anybody want to buy an ECU, wiring harnes, Z32 and stock MAFS, stock injectors, Apex Power FC, coil packs, 2 Ignitors, 3 solenoids, and all the idle crap? First $1200 takes it all....
