electrical problems
silvia652
Car: 240sx
my 93 240 keeps giving me problems it seems to be an intermitten electrical issue it will run perfect then all of the sudden wont start , it will crank but no spark, thr first time it was just a fuse but recently it happened and the fuse was fine, about 3 hours later it started back up before i determined if there was spark or lack of fuel if anyone has faced this before please help, i never know when or where it will happen next
metalsyth
Car: 2001 Nissan Altima
Just to rule out one thing is there any corrosion or dirt/grease/oil on either battery terminal or on other end of the wires?
Also under what conditions do these problems normally happen?
silvia652
Car: 240sx
the strange thing is that it has only happened twice, in the same parking spot on a slight incline but both times the gas tank was full so i dont see that as the problem, ive checked most of the connections, and cleaned the battery terminals, this all started after a strange gas station installed a new alternator
NISTECH
something is loose. check all your connections in the alt area. including grounds.
