Yes I have. I even taken it out and put in a friends 240sx and it ran. I'm just running out of ideas. I have also ordered a new. But, I'm going to check the grounds. If I can find any. A little lost in where to find where they are grounded at.OutToWinPAHC wrote:tested the motor out of circuit.
In my case I washer mode doesn't work also. You maybe fixed than me. I have two more months till my next safty inspection.sr_240sx wrote:I have a similar problem with the wipers first thught it was the motor test it out side and works then i said it has to be the switch bought one new and nothing water does come out so I don't know what could be if any ones know help us both.
Would that be the black or white box on the driverside?vancouverbc wrote:if the black wires are measuring 12v at the unit your ground is fine. tcu seems to be a critical component
http://img169.imageshack.us/im...0.jpg
Modified by vancouverbc at 7:37 PM 12/27/2009
What black or white box are you guys refering to? Well my problem still there don't know if my green box is out. The car is been at the garage for 3 years and at that moment they worked fine.DJ_SLapo wrote:In my case I washer mode doesn't work also. You maybe fixed than me. I have two more months till my next safty inspection.
green box in the engine bay close to your master brake cyln in the wiper relay. Or, I think that is. As for the black or white box. They are near fuse box on the drivers side. You would have to remove the kick panel cover to get to them. They are both held on with screws.sr_240sx wrote: What black or white box are you guys refering to? Well my problem still there don't know if my green box is out. The car is been at the garage for 3 years and at that moment they worked fine.
rear wipers have their own ampsr_240sx wrote:Yeap the relay box I checked them the only thing missing is the green box but I don't have another to try my rear wiper works so I don't know. In your case it has to be electricity.
Yes this all right. I have swapped all these parts and a rebuilt wipper motor and still no good. The amp is at location E50.sr_240sx wrote:The wiper amp is a green box next to the brake master cylinder. The TCU is near the underdash fusebox area. The wiper amp controls the autoreturn function. The TCU controls the time delay of the intermittent wipers.I found this info. maybe this is or problem!!!!!! the Timing Control Unit= TCM
I swap out with another one from the junk yard and still it didn't work. But then again the both switches could be still bad. Is there anyway I can't test them? I have the FSM but when you zoom on the harness you can't read the pin out. Where near the battery was it broken at? It could be a common problem for me to trouble shoot at.sr_240sx wrote:I found the problem the harness was broken on the baterry area I had a electromecanic coming home and fix it now I had to orther the right pivot and both rods from the wiper system. Did you check the switch?? the the level on the sterring wheel? that could be!!!
