dc1984 »
https://forums.nicoclub.com/dc1984-u34446.html
Sat Mar 28, 2009 1:55 am
try reseting ur ecu again. if no that, try checking all ur grounds, maing sure the connections are clean and tight.
one time i disconnected my battery and removed alternator to install an oil filter relocation and oil cooler, after that, putting the alternator back on and connecting the battery, a started my car to check for any leaks. after a few minutes of it idling, reving it up a bit to see if any leaks start, everything was good. i went to and pulled the key out of the ignition and when i was halfway out of my car, i realized that my car was still runing and i had the key in my hand and completly out of the ignition. in the end, it was just bad ground. never underestimate grounding in an electrical problem.
good luck
