divanian »
https://forums.nicoclub.com/divanian-u30158.html
Thu Jun 30, 2005 9:18 pm
I have more specific information about the flashing lights.
First of all it is the tail lights that flash along with the dome lights on instrument panel. They will stop flashing after about a minute but as soon as you activate anything electrical such as turn signal, open door, turn on headlight, depress brake pedal the tail lights and dome lights strat flashing again.
I took your advice went under hood into fuse box and removed the fuse for the tail lights. They still flashed without a fuse (fuse was blown) put in new fuse but it didn't make any difference. So without a fuse inserted into the tailight slot the tail lights still flashed.
One other thing when headlights are turned on the instrument panel lights (dome lights) do not come on except to dimmly flash in uinison with tail light.
Brake lights work, interior lights work, headlights work. All other components work.
Anyone have any other suggestion?
