darkspoon »
https://forums.nicoclub.com/darkspoon-u86733.html
Fri Jan 18, 2008 1:17 pm
So i have some electrical problems which need to be solved. Here are the problems and how i've tried to fix them:
Drove it for a day and a half off of my battery started and ran great, until the other day i went home, parked, turned the car off, ran into my house, came back out, (forgot to press the clutch in, but i don't think this is the problem), and my car acted as if the battery was dead (pressed the brake pedal and the digital clock fades/disapears.) and to no avail, car would not start. I boosted the car and it ran to the end of the street and died again. i boosted it and drove it home, again it died. after that my fuel pump fuses kept dieing, so i replaced the fuses, fuel pump and alternator. I replaced the fuel pump relay and that made the fuel pump fuses to stop blowing every 20 minutes, but the car still does not stay running.
Today i went out, boosted it, it will idle by itself, and for a period of time, but will barely drive further then 50 feet without dieing/stalling, and it won't start on it's own power, and only will start if boosted. if i press the brake pedal after its started the car will start to drop rpm's unless i add some gas, and the "Hicas" light flicks on for about a second then off.
The headlights don't go up or down, or turn on either, so i'm going to look into that.
So iask why isn't my car won't start by itself (it will start sometimes even if the boosting car isn't even turned on), why won't it stay running, why won't my headlights work, and how do i check if i have short?
