Ok here goes i switched over my headlights to LED and threw in the jumper MOD i read on the light switch to be able to run your lights High Low Fog whatever. well after doing that my turn signals went out. i switched out the flasher module and now the turn signals work. now the new problem when i put the right turn signal on the cluster lights blink with the turn signals or when i push the hazard light but that turns on right turn signal also. so i checked all the fuses they are good checked all the relays they are good took apart the light switch it is good took apart the dimmer module it seems good took apart turn signal switch and hazard switch its good. well basically im stuck now please help.
Jumpered the bottom right black wire to the green yellow 2 pins over.
also i noticed this connector on the drivers side fuse panel side is tied to ground any idea what this might be. this is the first non factory thing i have found that wasn't done by me and or what connector this might be.
This connector is just dangling what is it.
what is the white box pretty sure green relay is the check light relay.
is the black box and blue box on the bottom factory sort of looks out of place.
here is the drivers side where all these pics where taken to help for reference. thanks for the help just tying to get a better understanding of what the parts are
