DemonicSpeedz »
https://forums.nicoclub.com/demonicspeedz-u142939.html
Thu Oct 08, 2009 3:55 am
wiring is a night mare but your on the right track ok, you should be able to rerun the wire to its exact contact points but have you tried replacing your light switch
the mickey mouse effect is for the ones who dont have the patients to figure it out but if you hook up a secondary switch that will be fine to as long as it is ok with you, as for the radio was it the memory wire or the 12v key on wire cause both have fuses one is in line and the other is in the fuse panel if it was the memory that stays on constant then just replace that wire to the battery it is to much of a night mare to unraval all the wires to find that fuse.
if u find urself getting fustrated just take a minute to breath i have been doing driveability problems for the last 15 years and that is what works for me when i want to demo the car.
