Lee »
https://forums.nicoclub.com/lee-u1695.html
Sat Nov 22, 2003 1:50 pm
I have a 1992 240sx se. Its got about 160k in it all driving in/around Atlanta. The problem started a while ago when I had some water leak in by the side view mirror on the driver side (where the door hinge is, I think I had my window down a bit when it rained) . Initially I could not get my radio to work but my hud/digital speedo worked. So I got my radio directly connected to my battery at Best Buy, thinking this would bypass the bad wiring. The radio tech at BB said that I had 3-4volts coming in on the negative side of the radio fuse (driver feet area) when he tested it with a meter. Now, that the radio is connected to my battery, as soon as my radio turns on, when I start my car, my hud/speedo goes off. If I start the car with my radio off my hud/speedo stays on for the duration of the drive, otherwise when I turn on my radio as Im driving my hud/speedo disappears. The hud/speedo does not come back on if I turn my radio off after Ive started my car. I can see that there is some power to my hud as I can see a faint outline of the hud. Also my reading/dome lights do not work. If I try to turn them on, my door open light on my dash lights up. Further, my clock and my power seatbelts do not work unless I have my ignition turned to power on either. Currently I have a left front side marker blown which I will replace soon, dont know if that has anything to do with it. Any ideas/suggestions would be much appreciated. Thanks.
-Lee(btw anyone know of a good collision center for dents and dings or just a mechanic shop in general, around Atlanta? thanks)
