grecco28 »
https://forums.nicoclub.com/grecco28-u104357.html
Fri Oct 24, 2008 2:53 pm
that is correct the ecm is located in passenger side behid the kick panel, and the ecm use a relay to get power when you put the key on on/start position, you have to check if there is any power in the distribuitor, one of the wires shoud have the same voltage as the battery when the key is on or start position other wise the distribuitor does not produce any signal for the coil and the consecuence is no spark...
my recomendation is : try to check and fix wheres was the short to ground was and fix it first, then try to replace the relay with one of the same color,the color(check the pin arrangment to)of another non critical system, and try to start it....
